查看: 3083|回复: 6
[求助] Monster Count Plugin
发表于 2025-6-14 11:21:38 | 显示全部楼层 |阅读模式
Hi, is it possible to add this used to be in the old times of TurboHud, so we can move it to a different location? Thanks
Hud.GetPlugin<GLQ_MonstersCountPlugin>().XWidth = 0.84f;
Hud.GetPlugin<GLQ_MonstersCountPlugin>().YHeight = 0.61f;
发表于 2025-6-14 18:52:57 | 显示全部楼层
This code is valid, you can still do it this way
 楼主| 发表于 2025-6-14 20:52:34 | 显示全部楼层
Oh i see i did try to put it in plugingsX > glq > GLQ_PluginEnablerOrDisablerPlugin but didnt work, so i think i have to make it in the other folder plugings > user > PluginEnablerOrDisablerPlugin ? to work.
发表于 2025-6-14 21:04:10 | 显示全部楼层
Rob86 发表于 2025-6-14 20:52
Oh i see i did try to put it in plugingsX > glq > GLQ_PluginEnablerOrDisablerPlugin but didnt work,  ...
Any one of them will work
 楼主| 发表于 2025-6-14 21:41:07 | 显示全部楼层
Sorry for replying again , the thing is when I add it in plugingsX > glq > GLQ_PluginEnablerOrDisablerPlugin, then i press start to run turbohud  the GLQ_PluginEnablerOrDisablerPlugin just get over rewiten and it deletes that code.
发表于 2025-6-14 21:42:32 | 显示全部楼层
Rob86 发表于 2025-6-14 21:41
Sorry for replying again , the thing is when I add it in plugingsX > glq > GLQ_PluginEnablerOrDisabl ...
Add it after completely exiting the software
 楼主| 发表于 2025-6-14 21:47:57 | 显示全部楼层
Nice THANKS that worked great now
GMT+8, 2026-4-2 00:45 , Processed in 0.093265 second(s), 24 queries .
