查看: 2658|回复: 1
[求助] 角色在菜单启动导航时有 Exceptions 报错
发表于 2025-4-30 22:11:21 | 显示全部楼层 |阅读模式
角色在菜单时启动导航会报错。
进入游戏后再启动就正常。
一旦返回菜单后又报错。
请指点解决方法:
2项报错
2项报错
[C#] 纯文本查看 复制代码
2025.04.30 17:31:18.076	25.4.9.0	overlay paint error (System.NullReferenceException: Object reference not set to an instance of an object.
   at SharpDX.DirectWrite.TextLayout.GetMetrics(TextMetrics& textMetrics)
   at 16256.‍‍‭‭‍()
   at 0‍2.(Boolean ))
2025.04.30 17:31:18.194	25.4.9.0	overlay paint notification (SharpDX.SharpDXException: HRESULT: [0x88990001], Module: [SharpDX.Direct2D1], ApiCode: [D2DERR_WRONG_STATE/WrongState], Message: The object was not in the correct state to process the method.
   at 0‍2.(Boolean ))
发表于 2025-4-30 22:41:33 | 显示全部楼层
这个错误不会影响任何东西,不需要解决
GMT+8, 2026-4-1 21:12 , Processed in 0.111961 second(s), 27 queries .
