查看: 4092|回复: 7
求助
发表于 2024-10-29 15:45:14 | 显示全部楼层 |阅读模式
打开顺序谁教下   我按说明操作 没效果
 楼主| 发表于 2024-10-29 15:58:47 | 显示全部楼层
[2024.10.28 01:50:36.722] [09:50:36.724] exit 1 (1, 0)
[2024.10.28 01:51:32.240] [09:51:32.242] exit 1 (0, 0)
[2024.10.28 01:51:57.776] [09:51:57.778] exit 1 (0, 0)
[2024.10.28 06:15:30.944] [14:15:30.949] exit 1 (0, 0)
[2024.10.28 08:50:18.166] [16:50:18.167] exit 1 (0, 0)
[2024.10.28 08:58:18.373] [16:58:18.376] exit 1 (1, 0)
[2024.10.28 09:00:04.492] [17:00:04.494] exit 1 (0, 0)
[2024.10.28 09:00:43.777] [17:00:43.779] exit 1 (0, 0)
[2024.10.28 09:02:37.999] [17:02:38.001] exit 1 (0, 0)
[2024.10.28 09:03:39.833] [17:03:39.835] exit 1 (1, 0)
[2024.10.28 09:03:53.354] [17:03:53.356] exit 1 (1, 0)
[2024.10.28 09:12:34.736] [17:12:34.737] exit 1 (1, 0)
[2024.10.28 09:15:03.172] [17:15:03.174] exit 1 (1, 0)
[2024.10.28 09:55:58.583] [17:55:58.585] exit 1 (1, 0)
[2024.10.28 10:15:51.931] [18:15:51.933] exit 1 (1, 0)
[2024.10.28 10:16:36.690] [18:16:36.692] exit 1 (1, 0)
[2024.10.28 10:58:36.930] [18:58:36.933] exit 1 (1, 0)
[2024.10.28 11:04:27.646] [19:04:27.648] exit 1 (0, 0)
[2024.10.28 11:05:44.690] [19:05:44.692] exit 1 (1, 0)
[2024.10.28 11:07:27.768] [19:07:27.771] exit 1 (1, 0)
[2024.10.28 11:07:38.263] [19:07:38.266] exit 1 (1, 0)
[2024.10.28 11:07:44.935] [19:07:44.937] exit 1 (1, 0)
[2024.10.28 11:07:53.177] [19:07:53.179] exit 1 (1, 0)
[2024.10.28 11:08:16.662] [19:08:16.664] exit 1 (0, 0)
[2024.10.28 11:10:53.119] [19:10:53.121] exit 1 (1, 0)
[2024.10.29 02:11:05.804] [10:11:05.806] exit 1 (1, 0)
[2024.10.29 02:11:42.672] [10:11:42.674] exit 1 (1, 0)
[2024.10.29 02:11:58.360] [10:11:58.362] exit 1 (1, 0)
[2024.10.29 02:40:29.832] [10:40:29.834] exit 1 (1, 0)
[2024.10.29 02:40:41.122] [10:40:41.124] exit 1 (1, 0)
[2024.10.29 02:40:55.217] [10:40:55.219] exit 1 (1, 0)
[2024.10.29 02:42:01.959] [10:42:01.961] exit 1 (1, 0)
  日志  插件打不开
发表于 2024-10-29 16:17:04 | 显示全部楼层
[2024.10.28 01:51:32.240] [09:51:32.242] exit ...
看你这日志最后一条
就是你没使用降权快捷方式运行游戏
 楼主| 发表于 2024-10-29 18:28:32 | 显示全部楼层
TurboHUD 发表于 2024-10-29 16:17
看你这日志最后一条
就是你没使用降权快捷方式 ...
我打开降权快捷方式 弹出个黑框  过一会没了   也没啥反应
 楼主| 发表于 2024-10-29 18:29:36 | 显示全部楼层
看你这日志最后一条
就是你没使用降权快捷方式 ...
打开降权快捷方式 之前要先打开steam吗
发表于 2024-10-29 20:36:55 | 显示全部楼层
具体麻烦联系客服QQ远程查卡,如果运行不了的话原因很多的
发表于 2025-1-26 19:51:25 | 显示全部楼层
搞定了吗?
发表于 2025-1-26 20:37:45 | 显示全部楼层
麻烦有问题你直接找客服QQ解决吧,不要一直顶老贴
GMT+8, 2026-4-1 21:11 , Processed in 0.094311 second(s), 24 queries .
