查看: 11869|回复: 19
Bugs and sugestion
发表于 2023-10-12 05:32:25 | 显示全部楼层 |阅读模式
Hi,
Bugs:
- Aspect not showing in the Off-Hand (Sorcerer/Focus)
Sugestion:
- Ability to gray out all elements that do not match any filter. Like with the JackCeparou plugin Troubadour.
- For the sigils, the same thing as the blacklist but for our favorites.  Like highlighting the one you choose in a list without any bad afix from the blacklist. Those have 0 match with all list remain normal. Which will allow them to be checked manually.
Otherwise, for the moment everything is working fine!
Thanks
发表于 2023-10-12 11:55:20 | 显示全部楼层
need to added a 'Positive' list as their favorite?Just like the following
[C#] 纯文本查看 复制代码
Positive_AttackMoveSpeedOnKill
CooldownReductionOnKill
DamageReductionForMissingHealth
EvadeLeavesPoison
EvadePushesEnemies
FireDamage
FrostDamage
GoldFind
IncreasedCritChance
IncreasedHealing
LightningDamage
MagicFind
PeriodicLightning
PhysicalDamage
PoisonDamage
ShadowDamage
StunCausesBurning
Thorns
发表于 2023-10-12 12:47:17 | 显示全部楼层
Do you mean item filters?
 楼主| 发表于 2023-10-12 13:24:49 | 显示全部楼层
Yes and by their name exactly same as the blacklist plugin. My idea is more to be able to sort the sigils by their farming tier. Example of a tier list in maxroll.gg "https://maxroll.gg/d4/tierlists/nightmare-dungeon-tier-lists#solo-experience-farming-header".
For example to highlight the T1 and T2 dungeons without bad afix.
This will allow us to differentiate which sigils we need to dismantle and which ones need to be keep more quickly.
So do exactly like the blacklist plugin with all the dungeon names but to choose the favorites one.  Display with an colored border on the sigils in the inventory or with an specific icon.
In writing this:
"My idea is more to be able to sort the sigils by their farming tier. Example of a tier list in maxroll.gg "https://maxroll.gg/d4/tierlists/nightmare-dungeon-tier-lists#solo-experience-farming-header"
This gave me the idea to add an option to display the tier letter directly on the sigils in the inventory. In the same way as the ILVL.
Yes, the logic explened "https://raw.githubusercontent.com/JackCeparou/Troubadour/main/_Core/Extensions/InventoryGreyOut.cs"
发表于 2023-10-12 16:14:43 | 显示全部楼层
This sounds too complicated, I think you can see from the sigil icon that the dungeon name and its level are enough.
Due to the fact that nightmare dungeons cannot be reused, I believe that a positive list is also meaningless.
You should be farming in those not very bad nightmare dungeons
发表于 2023-10-12 16:16:14 | 显示全部楼层
For GreyOut, I believe it is also meaningless and may even conflict with the upcoming stash search function
 楼主| 发表于 2023-10-12 16:59:26 | 显示全部楼层
In the "NightmareSigil" plugin, in the list of the afixes, I think "Resource Burn" can be removed because it was deleted during the season.
For the highlight sigil you cant just use the same code of the "Dungeon blacklist" plugin ? And for the Render.GetTexture use another SupportedTextureId.
Sigil check
if favorite = 1
if aflix blacklist = 0 & dungeon blacklist = 0
render
发表于 2023-10-12 17:05:03 | 显示全部楼层
it will always be extracted from game data, and I do not want to manual maintain a list.
Of course I can.
But I don't think the significance of only highlighting positive affixes is too great
 楼主| 发表于 2023-10-12 17:50:37 | 显示全部楼层
Highlight the positive sigil by its dungeon name and not by the affix.
Like highlighting this one, if there is no blacklisted affix in it: Domhainne Tunnels, Hoarfrost Demise, Immortal Emanation, Mariner's refuge, Sarat's Lair, Uldur's Cave.Or juste delete the blacklist by name and replace it with a favorite list. Because personally I don't blacklist any dungeon names. Just the affixes.
There is no reason to blacklist specific dungeons. On the other hand, there is a prioritized dungeon meta
发表于 2023-10-12 20:12:28 | 显示全部楼层
You already have the display of dungeon names, I don't think it's necessary to add a super long list as a favorite dungeon list, it really doesn't make sense. On the contrary, for some specific builds, the types of monsters in some dungeons are very bad, which is why there is a blacklist of dungeons list.
Anyway, since you insist on me doing this, I will add it in the next update
GMT+8, 2026-4-1 19:58 , Processed in 0.105564 second(s), 25 queries .
