查看: 4935|回复: 2
Akarat's Champion skill prophet rune with akkhan set
发表于 2023-10-8 21:17:59 | 显示全部楼层 |阅读模式
Hi, can you update the macro for Crusader's akarat's champion skill when using Prophet rune with akkhan set to refresh the skill when the buff is down and when you get proced , at the moment it just refreshes all the time and doesn't wait until you get proced . Thanks
发表于 2023-10-9 20:57:56 | 显示全部楼层
when you CDR >=75% or (50% and (equipped akkhan set 4p or Obsidian Ring of the Zodiac or Akarats Awakening)), it will cast.
More other rules are used to protect you from death
 楼主| 发表于 2024-1-7 04:15:22 | 显示全部楼层
Hihi just want to say thanks, just loged back a bit in D3 and saw the Decemeber 18th update that you optimized Akkhan's macro the way i wanted it to work
GMT+8, 2026-4-2 00:45 , Processed in 0.082463 second(s), 24 queries .
