查看: 5364|回复: 5
Help me about performance of overlay Turbohud
发表于 2022-2-21 18:38:15 | 显示全部楼层 |阅读模式
Hi admin,
i have 1 problem I need help to fix
i have reinstalled windows 10 and windows 11 2 times and also reinstalled diablo 3.
All drivers I have updated to the latest from the homepage of Laptop Lenovo Legion Y740
1. My in-game settings are all low settings.
- Windowed (Fullscreen)
- anti-aliasing: None
- LowFX: Check
- SSAO: Uncheck
- Max Forceground FPS, Max Background FPS both uncheck
2. D3pref:
- DisableTrilinearFiltering: 1
- Hardwareclasses: 1
When I'm not using turbohud lightingmod in windowed (Fullscreen) mode, my FPS is very good and there is no lag
Until I used the HUD, everything got worse and the laptop's temperature was very high, more than 85 degrees
FPS reduced from 150 to 32
when i move all HUD overlays move and lag
I hope this can be solved
Thanks very much!!!
发表于 2022-2-21 23:54:20 | 显示全部楼层
If you have a integrated graphics, you shouldn't let TurboHUD.exe runs on the integrated graphics
 楼主| 发表于 2022-2-22 01:06:08 | 显示全部楼层
On my laptop only have Nvidia RTX 2060 and i using turbohud on vga nvidia
 楼主| 发表于 2022-2-22 01:07:40 | 显示全部楼层
i dont install intel graphics HD630 on laptop, i only install RTX2060
 楼主| 发表于 2022-2-22 19:14:46 | 显示全部楼层
i installed driver intel graphics hd630 and setup on BIOS "switch graphics"
Now i must be run hud with rtx2060 ?
发表于 2022-2-22 22:57:14 | 显示全部楼层
Now i must be run hud w ...
yes,and try
GMT+8, 2026-4-2 08:45 , Processed in 0.121347 second(s), 24 queries .
