查看: 5850|回复: 4
TurboMGR
发表于 2021-7-26 18:13:02 | 显示全部楼层 |阅读模式
TurboMGR does not update the stash until char goes to the menu. Before, it updated automatically.
发表于 2021-7-26 21:11:23 | 显示全部楼层
Thank you for your feedback
 楼主| 发表于 2021-8-2 02:07:35 | 显示全部楼层
I believe I have found the problem, when the follower is equipped and is following you, sometimes TURBOMGR does not update, if you dismiss the follower, then update normally. Is there anything related to the update on 7/21/2021, "2. Item Support Items Information Equipped in Follower Interface".
发表于 2021-8-2 06:25:31 | 显示全部楼层
rvj 发表于 2021-8-2 02:07
I believe I have found the problem, when the follower is equipped and is following you, sometimes TU ...
Thank you for your clue
回复 支持 1 反对 0
GMT+8, 2026-4-2 12:08 , Processed in 0.095315 second(s), 27 queries .
