查看: 5147|回复: 1
Possibility to rename TurboHUD.exe
发表于 2021-4-10 07:04:49 | 显示全部楼层 |阅读模式
Hi, is is possible to rename TurboHUD.exe to something else? For example have a configuration file that points to the corresponding .exe? I don't want the name "TurboHUD.exe" showing in the list of running processes. Thank you.
发表于 2021-4-10 11:08:08 | 显示全部楼层
You can't rename it, or it won't be run
btw, The anti cheating engine is not an idiot, it's ridiculous to try to avoid detecting cheating by renaming a process.
If it wants to ban you, it has 10000 ways to find you Look at rosbot
GMT+8, 2026-4-2 17:06 , Processed in 0.080278 second(s), 24 queries .
