查看: 33756|回复: 2
插件异常
发表于 2020-11-26 12:34:40 | 显示全部楼层 |阅读模式
2020.11.26 12:33:23.071        20.11.19.1        error while initializing plugins
2020.11.26 12:33:23.071        20.11.19.1                C:\Users\Administrator\Desktop\新建文件夹\TurboHUD_LightningMOD\TurboHUD\Plugins\LightningMod\SkillHandlers\Wizard\WizardHydraPlugin.cs(4,18) : error CS0101: The namespace 'Turbo.Plugins.LightningMod' already contains a definition for 'WizardHydraPlugin'
2020.11.26 12:33:23.071        20.11.19.1                C:\Users\Administrator\Desktop\新建文件夹\TurboHUD_LightningMOD\TurboHUD\Plugins\LightningMod\SkillHandlers\_Tests\EliteOrBossNearbyCursorTest.cs(6,18) : error CS0101: The namespace 'Turbo.Plugins.LightningMod' already contains a definition for 'EliteOrBossNearbyCursorTest'
2020.11.26 12:33:23.071        20.11.19.1                C:\Users\Administrator\Desktop\新建文件夹\TurboHUD_LightningMOD\TurboHUD\Plugins\LightningMod\SkillHandlers\_Tests\EliteOrBossNearbyCursorTest.cs(21,25) : error CS0101: The namespace 'Turbo.Plugins.LightningMod' already contains a definition for 'IsEliteOrBossNearbyCursorTestFluent'
2020.11.26 12:33:23.071        20.11.19.1                C:\Users\Administrator\Desktop\新建文件夹\TurboHUD_LightningMOD\TurboHUD\Plugins\LightningMod\SkillHandlers\Wizard\WizardHydraPlugin.cs(6,16) : error CS0111: Type 'WizardHydraPlugin' already defines a member called '.ctor' with the same parameter types
2020.11.26 12:33:23.071        20.11.19.1                C:\Users\Administrator\Desktop\新建文件夹\TurboHUD_LightningMOD\TurboHUD\Plugins\LightningMod\SkillHandlers\Wizard\WizardHydraPlugin.cs(11,30) : error CS0111: Type 'WizardHydraPlugin' already defines a member called 'Load' with the same parameter types
2020.11.26 12:33:23.071        20.11.19.1                C:\Users\Administrator\Desktop\新建文件夹\TurboHUD_LightningMOD\TurboHUD\Plugins\LightningMod\SkillHandlers\_Tests\EliteOrBossNearbyCursorTest.cs(10,43) : error CS0111: Type 'EliteOrBossNearbyCursorTest' already defines a member called 'Test' with the same parameter types
2020.11.26 12:33:23.071        20.11.19.1                C:\Users\Administrator\Desktop\新建文件夹\TurboHUD_LightningMOD\TurboHUD\Plugins\LightningMod\SkillHandlers\_Tests\EliteOrBossNearbyCursorTest.cs(23,51) : error CS0111: Type 'IsEliteOrBossNearbyCursorTestFluent' already defines a member called 'IfEliteOrBossNearbyCursor' with the same parameter types
2020.11.26 12:33:23.789        20.11.19.1        error while initializing plugins
2020.11.26 12:33:23.789        20.11.19.1                Metadata file 'C:\Users\Administrator\Desktop\新建文件夹\TurboHUD_LightningMOD\TurboHUD\plugins_compiled_1af72e21536ea87d1e417672f9576c091474c0e7.dll' could not be found
发表于 2020-11-26 13:54:47 | 显示全部楼层
删除全部文件重新下载
 楼主| 发表于 2020-11-26 15:41:05 | 显示全部楼层
谢谢。。。。。。。。。。。。。
GMT+8, 2026-4-2 19:11 , Processed in 0.082177 second(s), 24 queries .
