查看: 10280|回复: 3
启动插件后无反应
发表于 2020-10-16 12:30:29 | 显示全部楼层 |阅读模式
如题如图,请问要如何解决
J29Etc/GMT-8GMT-8000000202010161229285772..png
发表于 2020-10-16 17:19:44 | 显示全部楼层
具体请把插件目录下\TurboHUD\logs\exceptions.txt发出来或者把这个文件发给客服QQ,不然无法判断你的问题原因
 楼主| 发表于 2020-10-18 20:55:43 | 显示全部楼层
TurboHUD 发表于 2020-10-16 17:19
具体请把插件目录下\TurboHUD\logs\exceptions.txt发出来或者把这个文件发给客服QQ,不然无法判断你的问题 ...
2020.10.18 20:54:40.534        20.9.9.0        error while initializing plugins
2020.10.18 20:54:40.535        20.9.9.0                D:\Games\TurboHUD\TurboHUD\Plugins\LightningMod\SkillHandlers\DemonHunter\DemonHunterStrafeHungeringArrowPlugin.cs(8,18) : error CS0101: The namespace 'Turbo.Plugins.LightningMod' already contains a definition for 'DemonHunterStrafeHungeringArrowPlugin'
2020.10.18 20:54:40.535        20.9.9.0                D:\Games\TurboHUD\TurboHUD\Plugins\LightningMod\SkillHandlers\DemonHunter\DemonHunterStrafeHungeringArrowPlugin.cs(29,16) : error CS0111: Type 'DemonHunterStrafeHungeringArrowPlugin' already defines a member called '.ctor' with the same parameter types
2020.10.18 20:54:40.535        20.9.9.0                D:\Games\TurboHUD\TurboHUD\Plugins\LightningMod\SkillHandlers\DemonHunter\DemonHunterStrafeHungeringArrowPlugin.cs(34,30) : error CS0111: Type 'DemonHunterStrafeHungeringArrowPlugin' already defines a member called 'Load' with the same parameter types
2020.10.18 20:54:40.535        20.9.9.0                D:\Games\TurboHUD\TurboHUD\Plugins\LightningMod\SkillHandlers\DemonHunter\DemonHunterStrafeHungeringArrowPlugin.cs(46,21) : error CS0111: Type 'DemonHunterStrafeHungeringArrowPlugin' already defines a member called 'OnKeyEvent' with the same parameter types
2020.10.18 20:54:40.535        20.9.9.0                D:\Games\TurboHUD\TurboHUD\Plugins\LightningMod\SkillHandlers\DemonHunter\DemonHunterStrafeHungeringArrowPlugin.cs(73,22) : error CS0111: Type 'DemonHunterStrafeHungeringArrowPlugin' already defines a member called 'upStrafe' with the same parameter types
2020.10.18 20:54:40.535        20.9.9.0                D:\Games\TurboHUD\TurboHUD\Plugins\LightningMod\SkillHandlers\DemonHunter\DemonHunterStrafeHungeringArrowPlugin.cs(80,21) : error CS0111: Type 'DemonHunterStrafeHungeringArrowPlugin' already defines a member called 'PaintTopInGame' with the same parameter types
2020.10.18 20:54:40.535        20.9.9.0                D:\Games\TurboHUD\TurboHUD\Plugins\LightningMod\SkillHandlers\DemonHunter\DemonHunterStrafeHungeringArrowPlugin.cs(194,22) : error CS0111: Type 'DemonHunterStrafeHungeringArrowPlugin' already defines a member called 'DoHungeringArrow' with the same parameter types
2020.10.18 20:54:41.452        20.9.9.0        error while initializing plugins
2020.10.18 20:54:41.452        20.9.9.0                Metadata file 'D:\Games\TurboHUD\TurboHUD\plugins_compiled_6115d1e662214e1c8a2b1f82f7728380644e3de6.dll' could not be found
发表于 2020-10-18 23:53:35 | 显示全部楼层
你这个插件被你改坏了!缺少这个文件
GMT+8, 2026-4-2 20:41 , Processed in 0.102739 second(s), 26 queries .
