查看: 11417|回复: 2
左下角红字Unable to retrieve lastest version info for TurboHUD,导航不能使用...
发表于 2017-4-21 08:53:08 | 显示全部楼层 |阅读模式
按照帖子的几个方法http://bbs.turbohud.com.cn/thread-18-1-1.html都不能解决问题。
我发现我无论怎么修改hosts文件,包括设为只读,我启动导航插件,它都会把hosts文件修改为
# Copyright (c) 1993-2009 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
#      102.54.94.97     rhino.acme.com          # source server
#       38.25.63.10     x.acme.com              # x client host
# localhost name resolution is handled within DNS itself.
#        127.0.0.1       localhost
#        ::1             localhost
发表于 2017-4-21 13:07:25 | 显示全部楼层
不会就加客服QQ 点右边
GMT+8, 2026-4-2 05:48 , Processed in 0.100028 second(s), 27 queries .
