查看: 8559|回复: 2
提升下蟲洞吧
发表于 2020-1-5 17:08:30 | 显示全部楼层 |阅读模式
更明顯的顔色
// 作者:<TW>希多
// 日期:108.09.10
// 說明:顯示蟲洞效果的圈圈。(含聲音提示)
// 參考檔案:
// 參考路徑:
// 版本:
using System.Linq;
using Turbo.Plugins.Default;
namespace Turbo.Plugins.User
    public class WormHolePlugin : BasePlugin, IInGameWorldPainter
        public WorldDecoratorCollection WormHoleDecorator { get; set; }
        public WormHolePlugin()
            Enabled = true;
        public override void Load(IController hud)
            base.Load(hud);
            WormHoleDecorator = new WorldDecoratorCollection(
                new MapShapeDecorator(Hud)
                    Brush = Hud.Render.CreateBrush(220, 255, 0, 255, 1),
                    Radius = 8.0f,
                    ShapePainter = new CircleShapePainter(Hud),
                new GroundCircleDecorator(Hud)
                    Brush = Hud.Render.CreateBrush(255, 255, 0, 255, 3),
                    Radius = -1,
                new GroundShapeDecorator(Hud)
                    Brush = Hud.Render.CreateBrush(255, 255, 0, 0, 3f),
                    ShapePainter = WorldStarShapePainter.NewTripleTriangle(Hud),
                    RotationTransformator = new CircularRotationTransformator(Hud, 30),
                    Radius = 5f
                new GroundLabelDecorator(Hud)
                    CountDownFrom = 2,
                    TextFont = Hud.Render.CreateFont("tahoma", 14, 255, 255, 250, 250, false, false, 128, 0, 0, 0, true),
        public void PaintWorld(WorldLayer layer)
            if (Hud.Game.IsInTown) return;
            var actors = Hud.Game.Actors.Where(a => a.SnoActor.Sno == ActorSnoEnum._x1_monsteraffix_teleportmines);
            foreach (var actor in actors)
                if (actor.LastSpeak == null && Hud.Sound.LastSpeak.TimerTest(2000))
                    Hud.Sound.Speak("小心蟲洞!");
                    actor.LastSpeak = Hud.Time.CreateAndStartWatch();
                WormHoleDecorator.Paint(layer, actor, actor.FloorCoordinate, string.Empty);
        // Func End
发表于 2020-1-5 17:17:11 | 显示全部楼层
这种频繁出现的东西如果加入语音会严重影响语音序列
 楼主| 发表于 2020-1-5 17:22:31 | 显示全部楼层
語音可以去掉,看到就好了,據説是加了個六芒星的圖案,相當明顯
GMT+8, 2026-4-3 04:03 , Processed in 0.129395 second(s), 24 queries .
