楼主: stringer01
TurbiHud crashing / stops working
 楼主| 发表于 2025-4-4 00:27:10 | 显示全部楼层
I have played now 2 days and it seems to have solved the issue I've had. Thank you for the suggestion(s).
发表于 2025-4-4 00:34:12 | 显示全部楼层
stringer01 发表于 2025-4-4 00:27
I have played now 2 days and it seems to have solved the issue I've had. Thank you for the suggestio ...
It sounds like you installed a broken plugin that caused it to crash
 楼主| 发表于 2025-4-4 01:26:15 | 显示全部楼层
Must have been. I will re-add plugins one by one (more ore less) to see which one it is.
Thanks again for your time and help
GMT+8, 2026-4-1 19:45 , Processed in 0.080264 second(s), 23 queries .
