楼主: Gahleon
Have a few questions
发表于 2022-7-22 20:31:49 | 显示全部楼层
1.Disabling plugins has no effect on lag, You should make sure it runs on a separate graphics card, not an integrated one, and map loading lag issue is due to the need to find some key things in memory again, which depends on the CPU computing power
2.Which Rune?
 楼主| 发表于 2022-7-23 00:30:44 | 显示全部楼层
1. I am using pc, so by default it should be running on my graphics card right ?
2. I am using reflective skin rune.
发表于 2022-7-23 10:04:07 | 显示全部楼层
2. I am using re ...
You need to equip themortaldrama and convention of elements
and when the element rotate reaches 3 seconds before physics, it will autocast if monsters within 30 yards nearby
 楼主| 发表于 2022-7-24 10:56:59 | 显示全部楼层
Ok thank you
GMT+8, 2026-4-2 08:43 , Processed in 0.085245 second(s), 22 queries .
